slide out touch screen...will it fit? | Ford Explorer Forums
bigrob123
Cape Cod, MA
99 explorer xlt
hey guys ive looked but havent found yet...99 ex im looking to get a single din slide out touch screen moniter so i can keep the extra slot for switches but i wanted to make sure that the air vents in the middle top wont be in the way.
i wasnt sure if anyone has done this before or if they had to make any mods any help would be nice...i was almost set on this one http://www.crutchfield.com/p_110VM9114/Jensen-VM9114.html?search=Jensen+VENDORID110&tp=20217 just because im not looking to go all out and its cheap. any help would be great
thanks in advanved
I have a flip screen in my 98, pioneer dvd 5200. It blocks the vents when it is open, but mine has multi angle setting on the screen. I have an eq in my other slot where you are wanting your switches. You could reverse the kit, and put the switches on top of the stereo, but it would be blocked when the display is open. be sure not to let the vents blow directly into the back of the display, as it might cause condensation from the air, or overheat it from the heat. Easiest way is to close those vents when it is open, but it will fit. Also, watch out for shifting into gear too fast o nthe automatic, as the screen comes close to the lever when it is motorizing out.
