Nomad8326
- February 14, 2014
- Ohio
- 2004 Explorer XLS
Replaced:
-NGK spark plugs
-Bosch Plug wires
Cleaned
-Maf
-Dielectric grease at coil pack to wire connections
Only known issue gas tank evap appears to be messed up since I can only put a little over 1/2 tank of gas into the tank before it tries to spit it out the filler tube.
Seems to run smoothly when driving and was running better after i cleaned the maf but it was also 10F outside and when it warmed back up the misfire returned.
After sitting at idle it for a few seconds it seems to miss after randomly with no consistent interval sometimes 3+ seconds and other times one on top of another.
Any ideas?
-NGK spark plugs
-Bosch Plug wires
Cleaned
-Maf
Any ideas?
