Slight vibration at idle, weak acceleration, no error codes... | Ford Explorer Forums
Nuke'em
Seal Beach, CA
'03 Explorer V6 4.0 SOHC
Hello my fellow Explorer enthusiasts! I had a tough time searching through the forum to find someone experiencing similar symptoms as mine.
I have a 2003 XLS V6 Flex engine purchased used from private seller. I've had it for a few months now and I've noticed the engine doesn't quite perform like I think it should.
It has a noticeable vibration at idle/stop, poor acceleration and there are no engine error codes/CEL is off. I verified the light works upon light check with key on but engine off position with the ignition. I changed spark plugs, check plug wires (resistance and voltage drops), changed fuel filter, replaced knock sensor (just in case), put in a heavy dose of Berryman's B12 in tank for injectors, verified no vacuum leaks (good), replaced air filter, cleaned MAF sensor (twice), checked throttle body (seems good/clean), replaced PCV (just in case). That's all I can think of so far.
I plan on taking out the IAC valve next to clean and inspect.
But besides that does anybody else know of something I should check that isn't monitored by the ECM that could be the issue?
Thanks,
Mike
