Exp03Limited
- September 26, 2007
- Austin TX
- 2003 Limited AWD
I've been dealing with this for a few weeks now. I have a 2003 AWD Limited with 81k miles. When I'm at a stop and then turning I notice a slip or hesitation just a second or two after it starts rolling. It doesn't do it when going straight from a stop. Drives just fine after it gets rolling, I don't notice anything other than turning from a stop. It seems to do it mostly when warmed up. Anyone have other ideas what this could be before I take it in for service? I'd like to knock out the things I can handle myself prior to taking to a shop.
So below is a list of things I've done to try to remedy the problem and also because it needed it due to mileage. Nothing has helped.
Change plugs
Clean and oil air filter
Clean throttle body & MAF sensor
Replace fuel filter
Change transfer case fluid
Change rear differential fluid
Change plugs
Replace fuel filter
