pet575
- June 11, 2008
- Kansas City, MO
- 2004 Limited
Ive had the hesitation issue from time to time and it does not happen every time that I start from a stop. But it does seem to be getting worse, especially since the rough idle has begun. I also have slight hesitation when accelerating while in overdrive at speeds over 50 MPH.
The rough idle and slight hesitation in overdrive I can trace back to after I changed my intake. During reassembly, I noted that there is a plug on top of the throttle body assembly near the firewall that did not properly snap back on with the clip. It pushes on but, no matter what I do, it will NOT clip into place. I'm assuming that this is related to my issue and that this plug connects to the IAC valve.
Finally got a code last night when my Service Engine Soon light came on for the first time since the intake was replaced. Code is "0506 IAC System lower than expected."
Does this mean my IAC valve needs to be replaced or is this plug's failure to lock in place the more likely problem? Don't know what I can do about the plug other than replace it.
Thoughts?
Thoughts?
