JRay
- June 9, 2004
- Mississippi
- '03 XLT
I have a 2003 XLT, V8, with control track 4WD. Whenever the engine/transmission is cold, I feel a minor slipping with a slight grinding as I accelerate from a stop while turning....only when turning. It's the same sort of feel that you get when you have the 4WD locked in on dry pavement and turn your wheels, so I'm guessing that it's something to do with the lube in the transfer case, especially since the problem goes away once things heat up.
It's still under warranty, but I have no faith in dealers finding intermittent and "slight" problems. So, I'm starting here. Then I'll go to the dealer with some possible things to check. Any suggestions? Thanks in advance.
