slowly getting the ex back to where it should be | Ford Explorer Forums
white_shadow
north carolina
1998 explorer xlt v8
replace shocks, brakes, and wheel bearings last weekend
fixed the blend door a few weeks ago
today replaced the UCA and lower ball joints and got it aligned
it drives SOOO much better then when i brought it home
next item is tires, then start working on cosmetic
needs new bulbs in the fog light switch and the rear def switch, for some reason the drivers door lock pin wont go down, so the door does not lock, i need a new fog light, and thats about all that remaining to do. i still need to figure out the exhaust leak and why i have a CEL on, its something dealing with the cats. eventually i will drop the trans pan and chance filter/fluid and the same with the rear end. but thats a few weeks down the road. it shifts fine and there is no noise coming from the rear end, but i want to atleast change the fluid. overall, i am really enjoying this truck. i have never had an suv before. i see why people like them.
overall the UCA and ball joints were not a royal PITA, drivers side sucked because of the fuel lines.
