Godsent
- January 22, 2006
- Cedar Lake, Indiana
- '94 Eddie Bower
Ok, ok, I understand that the search tool is needed here, but I've been on this site religiously for the past 4 days and can't find exactly what I need. The closest I have gotten was the torsion twist forum and this quote "Your 91 uses coil springs, not torsion bars. To level yours out, you'll need lift coils or coil spring spacers."
I would figure my 94 would be the same thing. Now to the part where I just can't find any information on.
-Lift coils? These are bigger (longer) coils to extend the suspension?
-Coil spring spacers? These are the rubber inserts used to reduce the spring from contracting? I've read some bad things about the spacers on here, so is there any other alternitive?
"Suspension Helpers" Something I've heard of at school, just a rubber block on your leafs, are they worth it?
If nothing here aplies, I am looking for something small and cheap to start out with, that I (with almost no knowledge) can install myself. I do nothing more than run thru ruts friends leave for me at this time, so the demand on the lift wont be as high as what you all put yours through.
I just need something small to start with, to gain some beginner knowledge. Any help would be apretiated.
Again sorry about the redundant topic, but after a few days of searching, I decided just to post.
Edit.
This is it '94 Explorer
As of now I plan on buying a Grille Guard, I think I have one picked out but some suggestions there would be good too (installation dificulty, usefulness, looks, fog lamps and the such).
Edit.
