But for the problem, if it is smoking where exactly is the smoke coming from?
Have you changed or added fluids recently?
Does it smell like electrical components burning?
Check all your fluid levels, if your coolant is over full it could be spraying fluid out of the overflow tube, look for signs of coolant leak which will look like white corrosion near tubes and other radiator components. Also if its anything to do with the coolant you will have a white salty looking stain on the hood liner.
