soa question | Ford Explorer Forums
soa question
jackitup10
north carolina
when you do an soa do you need new shocks or do you use the stock ones? cause i have 4" lift shocks for the rear and i was planning on using them but the bolt up different than the stock ones
you should be fine using the ones you have for the 4 inch kit. some even use the stock ones. what most people do is use the sway-bar as a lower mount for the shocks. and i assume you know to get new spring perches.
let me know if you have any more questions.
doing SOA you can use the same shocks, use one of the sway bar mounts as a shock mount.
