Gokussj5okazu
- May 12, 2013
- Fredericktown, MO
- 1997 Explorer Sport
Hello there! I got a steal on a 97' Explorer a few months ago that had the dreaded timing chain rattle, and have had nothing but trouble since.
The first thing I did was pull the engine to replace the entire chain and tensioner system. While I had the pan off, I also found a chunk missing from the back of the oil pump. I eventually got the engine completely back together, and had little trouble getting it running once again. HOWEVER, it immediately had a mild tapping noise coming from the top front of the engine.
Removing the oil cap and using a bright light, I was able to look inside of the valve cover while the engine was running, and the upper tensioner was popping in and out. My first thought was that the tensioner was bad so I ordered a new one. Well today I got around to removing the old one and much to my surprise, there was no oil at all in the old tensioner or oil passage.
I removed the oil galley plug and attempted to spray WD40 as deep as I could, but the passage was blocked by what appears to be one of the oil passage restrictors from Ford. I did NOT install this when I replaced the chains and tensioners.
So can anyone think of a way to remove this restrictor without pulling the head and turning the thing upside down?
I suspect sludge has built up behind it and was preventing pressure from reaching the tensioner.
