Besides the lower intake looking warped, how did the gaskets on it look? did the protrude past where they set, Just did mine the other day as i did the upper before and no fix but after i did the bottom walla!! Problem solved. Maybe someone just re tighten the lower intake trying to solve problem and never changed the gasket, this could possibly make problem worse as the stock gaskets looked uneven to me half below where they set and half trying to seal. remember don't over torque intake after you change gaskets. upper calls for 53-62 inch lbs (just less than 5 lbs)and about twice that for lower.
