Recoil Rob
- April 5, 2008
- 2002 XLT
A little history first, I bought my 2002 new in Aug 2002 but having 2 other trucks did not have much use for it at the time. It sat for a while in a friends garage and the rotors rusted a bit and the rear pads have been on life support for a while. I knew the rotors were shot so I used it while my other truck was getting fixed, actually got down to metal on metal!
Tonight was the night, pulled the wheels, calipers and pads, no problem. Used the Clamp to compress the pistons and let the old fluid go out the bleeder instead of back up to the MC reservoir, will be flushing the entire system as soon as I am done.
Ah, the rotors! Since the truck only has 23K and I don't drive with the E brake on I didn't think the E brake pads would be a problem. I ripped off those two nut/clips on each hub and I started tapping the rotor fro the rear with a plastic coated mallet. Useless. Came inside to the computer and did a search here for rotor removal.
You guys are good. You, you're very good....
After reading through, I went with this procedure...
My E Brake pads have about 1/8" left on them, can I leave them or should I replace them while everything is open, hardware included. I have no idea how thick they start out at.
My Chiltons doesn't give lube points for the shims and other parts but i assume they should be done? I have CRC brake lube.
After a check on the fronts and everything is back together I have a Motive pressure bleed system ready to go. Does the EBrake cable need grease?
Also, any recommendations as to aftermarket rotors and pads?
thanks,
Rob
- Go to the drivers side, push the Ebrake cable and slip the 5/32" drill bit into the hole on the foot pedal
- Sprayed the where the studs and hub meet the rotor.
- Took SyberTigers advice and use a 1# sledge to tap around the outer perimeter of the disc. Just hard enough to bounce back, not dent, then move. Did this for about 3 revolutions.
- Took one pound sledge and hit back of rotor where caliper was with some meaning. Spin 45˚ and do again. Took about 4 -5 shots and she popped off.
thanks,
Rob
