Chrome_Rush
- November 17, 2014
- Dearborn Heights, MI
- 1991 Ford Explorer 2wd 5
I want to add the 2nd Gen flares to my 91. I know they mount using holes in the body but are they necessary, or could I just screw them into the fenders and rear quarters on the lips on the bottom and just use the 3m automotive double stick tape to mount them to the body instead of drilling all the holes? I'm going to patch up my rockers (haven't decided if I want to just use fiberglass or maybe try cutting out the rust then using slip over rockers (opinions?). I was just going to grab a set of 2nd Gen side skirts but the rear quarters have a few quarter sized rust spots starting as well I want to grind down and fix, but I want to throw the flares on to cover the work. I'm just trying to make it look as good as I can as cheap as I can, while also doing a repair that will last many years. I think the full 2nd Gen factory flare and side skirt kit fits the bill after the rust is fixed it will cover up all the body work.
Secondly, how do I remove the stuff? Does anyone maybe have a pic of the backside of the parts so I can see if there is a mounting surface for the double sided tape? 3rd, I'm debating what flares to use, it could be just an optical illusion on my part but the I want to say 98-01 XLS grey plastic unpainted flare kit and rocker covers look like they don't stick out as far as the ones found on the early second gen Eddie bauer models. They look slightly lower profile to me and I think may be a better option. I don't want to lift and I also don't want the wheels and tires to seem super sunk in with the flares. (Had the same issue with the flares in my gmc and had to add 2" wheel spacers to make it look right) I don't want to lift this and I want to run a set of 31x10.5 bfg all terrains I have. I'm guessing even with the xls flares (if they really are a lower profile then the eb set and will also work) I will still likely need to add a 1" spacer to the stock wheels with these tires to be happy with the look (and I'm hoping it won't rub) any input would be appreciated.
