Lamb-Of-God
- October 20, 2011
- Tampa,Fl
- 2001 Ford Explorer Sport
2001 Ford Explorer Sport 4.0L V6 112k
1: Driver side door locks,but doesn't unlock even when using the key.
I have to climb in passanger side,and pull handle to unlock it.
2: Low idle: On cold start 1,100rpm's after driving it runs 500-600rpms@ idle when shifted to park it wants to stall out,but usually doesn't.
**I do believe this to be the IAC,and will try cleaning/swapping new part.**
3: This one worries me a little bit. Every so often after a short trip when I try to restart the car it struggles a little bit to start up. It cranks fine,but definantly takes a little longer to finally roll over. Even a friend said it sounded bad when I cranked it one time - could this also be related to the IAC ?.
I'm not too worried about the first 2 Q's,but the 3rd issue is something that im very unsure about and a little worried could be a minor problem now,but a big problem starting it up later for work.
