Someone who knows what part this is? | Ford Explorer Forums
For the flashing OD light, take it to a tranny shop and get the codes pulled. The scanners that you get from a parts store won't do these.
I believe that "A" is a speed sensor
Can't see "B" well enough to tell.
B is the Vehicle Speed Sensor for your speedometer, and A is the rear sensor for the transfer case.
I get a code 646 - Incorrect gear ratio-fourth gear as the fault code. I've heared thas maybe because that the speed sensor is broken. Any ideas?
But is B the input speed sensor?
I am not positive, but I think B is the VSS Vehicle Speed Sensor. Post up some specs on your truck i.e. engine, transmission, year & model. I may have a photo of some 5R55E sensors.
BTW, P0646 is A/C compressor clutch relay circuit low.
Agree, "A" is the transfer case sensor. We do need specifics about your truck.
