muscleclone
- January 9, 2013
- Maryland
- 2003 Explorer Limited 4.6
Hello All,
I was browsing for cheap transmission deal in Philly area and see this post on CL. From price perspective, it looks pretty good for the whole install. I have been browsing this forum on transmission repair and preventive maintenance for awhile since I owned a 2003 Ford Explorer for little while. It will be a matter of time before I need a transmission rebuilt.
Hope this help someone in South Jersey/Philly area. I have no experience with or affiliate with this shop.
Rebuilt Ford Car/Truck/Heavy Duty Transmissions! - $1200 (Pemberton NJ)
© craigslist - Map data © OpenStreetMap
(google map) (yahoo map)
Mt. Holly Transmissions is offering you a special deal for your Ford passenger car, mini-van, or heavy duty/high performance pickup trucks! We are a complete transmission repair and installation facility offering complete rebuilding services as well as remanufactured and used transmissions! The common transmissions found in your ford vehicle are:
AOD, AOD-E, 4r70w, 4r75w- $1285 + Tax and Fluid. 5r55w/s/n, and 4r55, ax4n, and 4f50n. We will rebuild these transmissions and install them in your vehicle for $1435+Tax and Fluid. That price INCLUDES: Complete overhaul, consisting of new electronics, clutches, steels, gaskets, O-rings, steel rings, bushings, remanufactured torque converter, updated valve body with Sonnax and Superior components, updated pump assemblies. The ONLY exception is the 5r55, which is prone to premature wear in the servo bore, and if the case cannot be repaired, a new case must be purchased for $200. There are no hidden fees, no gimmicks, and no games played, and all transmissions leave with a 12 month or 12,000 miles warranty! HEAVY DUTY F-SERIES PICKUPS: e40d, 4r100 transmissions are also $1435+ Tax and fluid and consist of: an OEM solenoid pack, updated valve body, updated pump, all new clutches and steels, gaskets, seals, O-rings, steel rings, and most hard part damage! These prices are DONE AND INSTALLED, DROP THE VEHICLE OFF AND PICK IT UP WHEN ITS DONE! If you have any questions, please don't hesitate to call us! WE DO HIGH PERFORMANCE APPLICATIONS AS WELL!
105B Ft. Dix Road
Pemberton NJ 08068
105B Ft. Dix Road
Pemberton NJ 08068
