mbruffey
- March 21, 2006
- MN, MN
- 1997 5.0 AWD Eddie Bauer
97 EB 5.0. NO CODES.
Problem: Intermittently the engine will develop a slightly fast idle when warmed up, about 900-1000 RPM. Normally it hangs around 700. This is the classic symptom of a vacuum leak, and I think that this is possibly verified by the presence of tons and tons of "uncalled" misfires. But, perhaps low fuel pressure instead?
(Note: the TP sensor voltage fluctuates a little at idle but not enough to cause this. TPS does change the advance about .5 degrees up or down when it fluctuates, and remains between 17 and 20 degrees. I think that I will replace it but I really don't think that its the cause of the problem I'm after here.)
I can read a LOT of codes with the computer software with engine running. After scanning a number of outputs for a while, I noticed that the FUEL TANK PRESSURE was NEGATIVE 10 at the same time that the SPARK ADVANCE was "stuck" on 25. All this is at dead idle at 900+ RPM in park.
I decided to remove the GAS CAP. FUEL TANK PRESSURE goes positive (+0.6) and SPARK ADVANCE returns to 18 degrees. Put cap back on; fuel pressure goes negative again and advance back out to 25 degrees.
Software indicates that the FUEL TANK PRESSURE has something to do with EVAP/PURGE operations. I'm guessing that under certain conditions the system goes into an EVAP cycle (fuel tank was FULL at the time I'm reporting here). I had replaced the EVAP Solenoid under the battery compartment last summer, and did upper and lower intake gaskets too, to eliminate possible vacuum leaks. Gasket change improved idle, but not fix this issue. (Been chasing this one a long time.)
Guesses:
(1) Vacuum Leak when EVAP on
(2) Low Fuel Pressure = LEAN (but why advance go high then?)
Three other bits of information:
(a) Fuel Pump Secondary Monitor High = YES (NORMAL?)
(b) Fuel Pump Duty Cycle = 100% (NORMAL?)
(c) Case ground for the Fuel Pump Varies from NEG .07 to NEG .09 depending on RPMs. (more neg with accel)
Questions:
(1) Does the EVAP cycle normally kick the advance to 25 degrees? It is stuck exactly on 25 and does not fluctuate a bit.
(2) Does the EVAP cycle open a line that could be the cause of a vacuum leak?
(3) Should the tank "breathe" during EVAP to prevent negative pressure? Could the charcoal filter be full, or some line to/from it be clogged?
Thanks in "advance" for your kind input!
mbruffey
Guesses:
Questions:
mbruffey
