spark plug boot removal?? | Ford Explorer Forums
markp11
2000 ford explorer
Is there a certon spark plug boot tool. that would make it easyer to get the back 2 boots off the passenger side. on a 2000 ford explorer?? not enough room to get my hand in. they seem to be seased up..
Take your pick. Your knuckles will love you for using it. LOL
Helps if you twist them back and forth to break the seal. GL
www.sears.com/craftsman-spark-plug-pliers/p-00947315000P
www.sears.com/lisle-spark-plug-wire-puller/p-00915314000P
Both of those seem to be out of stock at Sears. I found the Lisle puller on Amazon Lisle 51250 Spark Plug Wire Puller or AK Garage Spark Plug Wire Puller
My wires didn't come off with a twist and pull and left residue on the plug.
I put on some gloves on twist and pull cut myself anyway then cuss out the cut up hand then blame my meds ;)
Just remove the front wheel. Saves you a lot of anger.
