Spark Plug gap on 91 explorer? | Ford Explorer Forums
Karl
Can anyone tell me the proper spark plug gap on a 91 explorer 4.0 liter? I am changing them myself. I have a miss in my engine when I put it under a load, so I am starting with plugs and wires first.
I don't have a manual yet.
Any help would be greatly appreciated.
Thanks, Karl
a call to your local auto store should tell you what it is.
I think I have read on this site that if you have a miss in your engine under load it could just be your MAF (mass air flow) sensor needing cleaning. You can find the instructions under Explorer tips on the main page.
Hope this helps
Brian
91 XLT 4x4
[This message has been edited by Brian1 (edited 03-09-2000).]
Karl,
From what I remember with mine, it is .054". I don't have my service manual with me but I am almost sure of this.
Ira
91 XLT 4x4
How can you tell when you've run out of invisible ink?
I think Ira is correct. Just lift up the hood and check one of the stickers - it has the info.
Gap is .054".
DOGMAN
91 4dr 5sp
5.5" Superlift
"Downhill is just uphill in the opposite direction"
Thanks for the help guys. Sounds like the
gap is .054 and I will also try cleaning the Sensor in the MAF.
-Karl
Just closing here.
I changed the plug wires and plugs. Solved my problem with the miss.
I also cleaned the MAF sensor. That only took about 15 minutes.
Thanks for the help. I adjusted the gap to .054 and she's running smooth.
-karl
