Speaker Crackle | Ford Explorer Forums
Speaker Crackle
Gannon
Menomonee Falls, Wisconsin
'92 XLT
I installed a pioneer stereo a few months ago myself. When I was done everything was fine. Recently one of my rear speakers started to crackle when I go over bumps. Is it a bad connection or is the speaker about to give out on me? I am not extremely stereo literate so any help would be appreciated. Thanks.
if it is when driving over bumps, then check the connections. it could also be the factory amp if you didnt bypass it. that is a very common problem with the stock amp.
The same thing happened to me. I installed the system myself and had one loose wire going to my driver side door. It would crackle over every bump I hit. Just remove your head unit w/o disconnecting the wires and move each one around a little bit until you find which one is loose.
