Speed sensor frustration. | Ford Explorer Forums
Blackbeard
Dallas, TX
1993 Aerostar
If I've overlooked the answer to this somewhere, I apologize. But I've searched this forum and others online and just can't get the answer I need.
I am trying to locate the speed sensor to replace it, hoping that will fix the wildly crazy speedo needle. Have already replaced the sensor on top of the differential. Now have a sensor that is supposedly mounted on the driver's side of the transmission, but nothing there looks like the sensor that I bought. Did I get the wrong sensor from Auto Zone? Or is it located elsewhere?
:banghead:
93s do not have a sensor on the transmission. I would look for shorting wires now that you have replaced the rear end sensor. I could be that there is a wire jiggling as you drive that is driving your gauge nuts.
Thanks, guys. I will check those out this weekend.
