Speed Sensor Help | Ford Explorer Forums
Speed Sensor Help
badgett
Mount Airy , North Carolina
1998 XLT 4.0 SOHC 4x4
I found one speed sensor by the tailshaft at the back of the transfer case. Where is the other one ?? (98 xlt 4.0 SOHC, 5 speed auto)
There are two in the t-case, the one you found near the driveshaft (& fill plug). The other is behind the shift motor. Since you're gonna be cleaning the motor (to fix your 4Low problem), you'll see it.
