fishnmaine
- August 16, 2010
- East Waterboro, Maine
- 2004 Sport Trac 4x4 Auto.
OK I've seen plenty of post on speedo cluster issues. But haven't seen my issue.
Sometime my speedo works for a couple of days then it acts up again. This is what happens. I'll be driving then all of the sudden it gets stuck on a certain speed. And sometimes when this happens i'll start up again from that point were its stuck. Lets say its stuck at 40 go down the road doing 40 (on my GPS) speedo would read 80. Or it would just stay stuck and not rebound. So how i fix this problem is unplug the battery to reset it back to normal and i'm good again for between a day to a week. And when it does it again unplug again etc etc. I checked all my grounds took the cluster out examined all wires took the steering column apart checked all connections. unplug and plug all connectors........The only thing i did not replace was the OSS sensor...Now would the sensor cause this issue or is it a bad cluster.....And i tell you what finding one is next to impossible. New one $570 ouch!! Imput would be great...
Thanks This is for a 2004 ford sport trac 4x4 automatic trans.
