Sporatic Reverse Issues | Ford Explorer Forums
newfie rider
Newfoundland
2002 Sport Trac
I have searched this site, and cannot seem to find a similar issue.....here it goes....hopefully someone has some suggestion:
History:
I bought the truck for a winter rig (to park the Beemer winter) a few months ago. It was parked for a few months. The truck had the typical shifting hard from 1st to 2nd issues with the 5R55E. I replaced the valve plate and gaskets, new filter and oil.
Worked fine for a few days until it started pouring transmission fluid out of the intermediate servo cover! :mad:
Picked up a new servo and servo cover and fastening clip, had that installed in a garage as I was tired of being on my back trying to work on it (plus it's jammed against the exhaust...not much room for my hands :D).
Got the truck back from garage, and the damn thing won't move in reverse when transmission is at operating temperature...:(
QUESTION????
I am HOPING it is just the reverse servo!
When I drove it home from garage, it moved in reverse for the first few times. Later same day, when put in reverse it wouldn't move at all.
I managed to limp it home best kind (shifts great in all forward gears). Truck has been parked in my driveway the last few days. I just started it up to move into my garage so I can jack it up and take a look at it, and I tried the reverse....WORKS FINE!
I don't want to take a chance driving it until I resolve this issue.
It seems that the reverse band is okay. Am I correct in assuming the reverse servo is bad?????
I am after spending a small fortune in Mercon V oil, and before I drop the bottom pan on the the tranny I would like an idea to what to look for.
Any help at all would be greatly appreciated.
Rick
UPDATE:
I replace the back inside servo for reverse, new fluids and gaskets. Still slips when transmission fluids ward up.
Adjusted the intermediate servo band (found instructions on this sight) Never worked! Found out that the reverse works of the third gear not 1 and 2.
Here we go, I don't seem to be getting much help fro this site...
After all the work has been done, transmission has no reverse when transmission fluids warm up.
Before I started this whole repair project, the transmission worked fine in reverse, the only issue I had was 1st/2nd shifting stemming from the valve gasket (This has been fixed)
The leak from intermediate servo cover came after (Fixed with new intermediate gasket/servo/cover)
No reverse when fluid warms up
Replaced rear inside servo mechanism and gasket
Still no reverse!
Is it possible there is dirt or debris in the veins in the valve body? Would one of the hydraulic actuators bad on the valve body?
Should I just buy a new valve body and take a chance that nothing else is worn in the transmission?
Or should I pick up a (hopefully) working transmission from a scrap yard?
Any constructive help would be great
Rick
^^^^^^^Thanks bdmaash, I didn't see that thread when I was searching...I will take a look and research what my options are
