beanstump
- February 11, 2024
- Farmington, NM
- 04 Ford explr. 2wd 4.0 v6
Hi everyone, New to forum first post. I have a 2004 explorer 4.0 l v6. 2wd. I have a constant squeal when in reverse only coming from the front. I also have a clunk( just once) when coming to a stop at slow speed, forward and reverse. I have replaced both outer tierods, upper and lower ball joints, both hubs,rotators, New brakes, New tires, and alignment. Calibers seem to be fine. No in and out movement on inner tierods. Control arms and bushings look good. Sway arms look good. No pulling when driving. Do have a shake when on the highway and steering feels loose when turning right. Not sure what else to check without taking it to a shop. Not sure I want to fit that bill. Any suggestions?
Thought I would add that squealing does not change when brakes are applied.
