- July 26, 2004
- Willow Grove, PA
- '97 XLT
Alright guys, help me try to figure this one out. Last week I seafoamed my X, and was thrilled with the results, as I explained in this thread. I also added 1/2 can of seafoam into my gas tank after and since I've been having issues with stalling and the engine throwing codes. Throughout the week, when starting the truck, it's acting like there's a vacuum leak. It'll kick off and then sputter to a stop and stall out. I'll have to step on the gas immediately after starting it up to get the RPMs up, and then throw it into drive and it's fine. A lot of times it doesn't really have an issue when started hot, but cold it's stalling, which is strange.
I was convinced it was the seafoam in the gas causing a lean fuel mixture issue of some sort (see codes below), but I've since polished off the fuel and re-filled the tank, and the problems persist.
Today I cleaned the hell out of my MAF, thinking I fouled it with oil (as I also cleaned my filter last weekend) and disconnected the battery to reset the computer with the new tank of gas. Still having issues.
I've jotted down the codes below that the truck has been throwing. I found what some of them are, but the vast majority are a mystery.
P1234 – Fuel Pump Driver Module off-line
P0174 – System too Lean (Bank 2)
P0171 – System too Lean (Bank 1)
P0040 – ?
P00C0 – ?
C0490 – ?
U0C92 – ?
C20C8 – ?
P0070 – ?
P0734 – ?
If anyone can help me identify the remaining codes or offer any advice I'd appreciate it. It's behaving like a vacuum leak, but I'm not sure a vacuum leak would cause these codes and be something that behaves differently with a cold vs. hot engine.
Thanks in advance...
P0040 – ?
P00C0 – ?
C0490 – ?
U0C92 – ?
C20C8 – ?
P0070 – ?
P0734 – ?
