MotoDog
- August 30, 2016
- Yucaipa, Ca.
- 1996 Ford Explorer
Ok, on 96 4.0L had heating problems for over a year. Loss of water. Finally after limping home on bottled water from the 24 packs of drinking water I took it apart. Turns out, the metal pipe (thermostat housing) had rusted out.
A little hole on the bottom. Figures because we have been putting water in it for a year with no coolant.
Ouch, lots of rust coming out!
So, the local Parts Store ordered a replacement pipe-Housing. This was the 40 mm one. Not at bad price!
Less than $18 by Dorman.
Next all day, 2 times off and on. Dropped those 6mm bolts into the dirt 10X!
New thermostat finally throw in boiling water for check. I can not get the dash
Gage to come up to normal temperatures! It used to set Half way, and when it overheated went upwards.
Now, it sets at cold, and some times a quarter a way up? I just drove 10-15 min drive. I never saw it go much past cold? I finally drilled a small (3/32") bypass hole in the new thermostat. I wonder what is happening.
Maybe needs air burping?
I don't want to fry the engine because the water temp is funky. I would change the T Sensor, but it worked OK a few days ago. So, I am left driving around with the Gage on C or a little past it. I wonder if the water is getting to the sensor?
Wondering what the REAL engine temperature is?
Mike
Mike
