My starter continues to run after the engine has started. Also, it continues to run after turning the ignition off and removing the key. I replaced the solenoid and the ignition switch module located at the bottom of the steering column. Anyone ever had this problem? Need help asap please.
When it rains it pours....had a brake pad shatter last night and sounds like my pass. side wheel bearings are shot.
Randy
Randy
