kevin.rehling
- February 15, 2013
- 1993 ford explorer
:exp:I have a 1993 Eddie Bauer" explore, 4.0 MFI AT with 153K miles. I have had it 3 years and has been a good vehicle. A year a go it started having starting problems. I had to constantly change the battery clamps for corrosion in order to get it to start.. The battery was only 2 year old then. Last week it finally quit. The starter sounded like it was bogging down and then would not start. I changed the battery clamps and no luck. I replaced the battery which was 3 yr old now. It started twice and no more. The main power cable to the starter was old and corroded. Put a new one in, no luck, just clicks at the relay on the fenderwell. I changed the starter relay, no luck, I changed the starter solenoid no luck. Autozone tested the starter twice and it passes twice. Tried to bump start it with a screwdriver across the relay, nothing. we checked for chassis and electrical ground with a meter, no luck. Ran a heavy duty ground cable from the starter mount bolt to the negative battery side, nothing. Did the starter test by disconnecting the ignition sw relay and it passed. Help? I have ran out of ideas and am sure the starter is ok. We also tried to get the solenoid to kick by a direct link to the battery and ground. When the problem started I would have to constantly tighten and clean the battery terminals to get it to start. I even tried to start in in Park and Neutral to see if the Park-neutral path was good, no different, just clicking at the relay. Please help.
