steering stabilizer | Ford Explorer Forums
steering stabilizer
xplore-this
Marion, IN
'98 XLT
do they make steering stabilizers for the ttb on 1st generations.
yes
(do a search hint hint)
Rancho has them, skyjacker offers both single and duel, and I think rough country. There are others out there, these are only ones I know of. I prefer the skyjacker duel myself.
thanx i am getting the skyjacker class 2 6'' here before too long i guess i'll check into it then.
That's a good lift, I would go with the deuls with that hieght and tire combo, I assume you are going to 33's.
no actually i am going to go with 35's and a 3 in. body lift. so i will definatly need to with stabilizers and prbably duels at that.
I run a single rancho stablizer with 33's, and it must have been one of the best things I did... seriously smothed out the ride.
Chris
xplore-this
James Duff has one, best thing is you can order only the brackets and buy whatever damper you want. Around $50 you can get it to your door. Not sure it will work for the lift your wanting though!
does it tell you which stabilizer to go with like the size of it and you just pick the brand or do you have to measure it.
