Steering wheel compatibility between 2013 and 2017 FPIU | Ford Explorer Forums
edougawa
CA
2021 Explorer Limited 4WD
Hi,
I did a steering wheel upgrade (?) for my 2013 PIU just for fun. I swapped it with a steering wheel from a 2017 PIU because I loved that all black color, and the red aux buttons are charming. I somehow managed to get most part of it working except the cruise control. The arrows on both left and right is working fine, the aux buttons working fine (it's odd that the aux buttons on my 2013 steering wheel doesn't work at all while the 2017's work fine without any tweak).
I got the following code from Forscan.
Code: B137F - Steering Wheel Left Switch Pack
Additional Fault Symptom:
- Component Failures
Code: B1380 - Steering Wheel Right Switch Pack
- Circuit Voltage Above Threshold
Code: U2101 - Control Module Configuration Incompatible
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
I compared the wiring diagrams and pinouts looks identical. I ordered a brand new working switch from Ford but no luck on that too. I also tried to play with BdyCM and SCCM using Forscan but need an as-built config from a working 2013 PIU for comparison.
It won't bother me too much as I rarely use cruise control but it would be great to get it fixed. Any suggestions will be appreciationed
Thanks and cheers.
