Stereo Install question | Ford Explorer Forums
Mounty 09
Nothern IN
1997 Mountaineer
My dad has a 2004 EB with the factory sub in the back and he also has a 2001 mustang with the mach 460 stereo. He Is wanting to put a new head unit in his explorer (he really likes the one I just bought). But on his factory radio he bought a plug so he can plug in his mp3 player. I was woundering if we could take the mustang radio out and put the explorer radio in his mustang?
Thanks
you will have to take the factory harnesses apart, unless the connectors are the same. but if you buy some environmental splices and bust out the crimper, here are the wire standards....
Wire Color Function / Vehicle Connection
Yellow = 12 Volt Battery / Constant (12V+)
Red = 12 Volt Ignition / Switched (12V+)
Blue = Power Antenna
Blue/White = Remote Turn on (12V+)
Orange = Illumination / Dimmer
Black = Chassis Ground (12V-)
White = Left Front Positive (LF+)
White/Black = Left Front Negative (LF-)
Gray = Right Front Positive (RF+)
Gray/Black = Right Front Negative (RF-)
Green = Left Rear Positive (LR+)
Green/Black = Left Rear Negative (LR-)
Violet = Right Rear Positive (RR+)
Violet/Black = Right Rear Negative (RR-)
