drolls
- March 19, 2015
- 2001 explorer awd 5.0
I have a bad vibration that gets worse at highway speeds. Rubbing/humming sound going 65+ and when getting out of the throttle. Here's what I've done so far. Checked wheels for play, no noticeable play. New tie rods, balanced tires and alignment. Changed fluid in front and rear diff, transfer case and tranny. Fluid was a little dark but didn't smell and no metal shards. I'm now getting a high pitched whine that started only when accelerating but I now hear it when idling in park. Idle moves around a bit between 600-1000 rpms. What do I do next? Check pulleys, iac? Can the iac cause vibrations at speed? Sorry guys, I'm learning as I go, any help would be greatly appreciated. Forgot to mention. I also changed the u joints on the rear drive shaft, they were in rough shape and binding a little but that didn't solve it.
