tac0meat
- May 29, 2000
- 91 EB 2x4
ok ive had the thing tested like 5 times and cant seem to pass, i have things done to it each time. the only part that i keep failing is the NOX. i fail it on both the low speed (15mph) and high speed (25mph) tests. heres a breakdown of what its been doin:
---------------limit------15mph---------------limit------25mph
test one: (lost sheet but the NOX were: )
NOX(ppm)------1046-------2050-----------------956-----1950
test two(replaced second cat and pvc valve <50miles on new cat):
HC(ppm)-----151--------9 ----------------------155------14
CO(%)--------1.68-------0.00-------------------1.31------0.00
NOX-----------1046--------1680------------------956-----1470
dilution------->6.0--------14.4------------------->6.0 -----14.4
test 3(>500 miles on new cat)
HC(ppm)----151----------11----------------------155-------13
CO(%)-------1.68---------0.00 -------------------1.31------0.00
NOX-----------1046---------1374-------------------956-----1704
dilution----->6.0-----------14.4------------------->6.0-----14.3
test 4(guy claims he adjusted timing by removing a plug in a wiring harness under hood)
HC(ppm)-----151--------12----------------------155------17
NOX-----------1046--------1516------------------956-----1488
dilution------->6.0--------14.3------------------->6.0 -----14.3
test 5(at different shop who claims all they did was use a fan to cool it down and let it sit for an hour)
HC(ppm)-----151--------39----------------------155------98
CO(%)--------1.68-------0.04-------------------1.31------0.16
NOX-----------1046--------891------------------956-----972
dilution------->6.0--------14.6------------------->6.0 -----14.8
test 6(back at my usual emissions shop, letting engine cool down for an hour with fan)
HC(ppm)-----151--------18----------------------155------24
CO(%)--------1.68-------0.00-------------------1.31------0.01
NOX-----------1046--------1551------------------956-----1503
dilution------->6.0--------14.5------------------->6.0 -----14.5
i watched all test performed except test number 5, which was at an "emissions specialist". the place that replaced my cat (not the same place i had my testing done at) said that my front cat is still good, and only need to replace the rear cat. after test 4, i replaced the plug that was supposed to advance my timing. tommorrow im gonna try running it ice cold just to see what happens (guy with 91 aerostar with same engine/tranny as me did it this way and supposedly passed). sorry for the long post, but im hopin somebody will understand what goin on with these numbers and have a suggestion to get it to pass. thanx guys!
