strangeKRS
- December 30, 2011
- Wadsworth, Ohio
- 2007 Mercury Mountaineer
My name is Keith and I have a 2003 X Limited 4x4 with a 4.0 SOHC. The truck has approx 156,000 miles and I am NOT the original owner.
The X is currently out-of-commission and I am trying to figure out the cause. While driving I lost power; it didn't quit running, but I couldn't drive Hi-way speed; I limped it off the road, then had it towed home. At first it would start and idle, but die as soon as the throttle was touched; Also heard what sounded like a vacuum leak while it idled. I Pulled plugs and found them way out of spec and worn to the nubs, so I replaced the plugs and wires. After that the truck wouldn't start until it sat for a day, then the same idle, but die. Tried cleaning the MAF and the IAC, with no improvement. Replaced the MAF - NO improvement. Changed the fuel filter, then after the first day, once it ran and died, it would no longer start. Pulled intake off, cleaned it and put new o-rings on. Same result - still hissing when it did idle for a minute. Checked fuel pressure, reading 62 PSI - only dropped 10 PSI over 2 hours. Checked again while cranking motor over and fuel pressure still read about 60 PSI with no spikes and only a few drops in pressure while cranking. Checked spark on a few plugs (both sides of motor) and it was strong and blue. Replaced Coolant temp sensor - NO change. EGR opens and closes when vacuum is applied.
Pulled plugs after no start and they are wet.
Pulled Fuel pump relay and cranked motor; it will start for a few seconds on the gas in the cylinders and fuel rail.
Does anyone have any input? I don't have a lot of money and really don't want to take it to the shop and have them throw parts at it hoping that it will fix the problem.
OH, and I am getting NO CODES. I only have a Scan tool, so little data there.
Now it will only start for a second, then die - and only if I hold the pedal to the floor
So:
2003 X 4.0 SOHC Limited 4x4 - Stock
Replaced:
Intake Gasket (O-Rings)
Plugs
Wires
Coolant Temp Sensor
MAF Sensor
Evac Hose to intake (Looked a little worn)- one of the canister purge valve lines
Fuel Filter
Cleaned:
Intake
Throttle
IAC
EGR
Has:
Fully Charged Battery
62 PSI Fuel Pressure
Good Blue Spark
PLEASE HELP
So:
Replaced:
Plugs
Wires
Coolant Temp Sensor
MAF Sensor
Fuel Filter
Cleaned:
Intake
Throttle
IAC
EGR
Has:
Good Blue Spark
PLEASE HELP
