stock amp and sub? | Ford Explorer Forums
stock amp and sub?
robtoy_r
Saint albans vermont
96 XLT
first off i have no clue what sound system i have. anyways i took the radio bezel off and there is like a black box mounted to the left inside the dash does anyone know what that is? i figured it might have been an amp but i read on here that the amp is in the rear right panel so i took that off and mounted in there was what i belive to be an amp but i see no sub? any idea on what these are or where the stock sub would be? sorry if this has already been covered but i didnt find much on my searches
The stock sub would be in the rear panel you removed to see the stock amp.
If your back cargo area has a pocket with a net, then you do not have a stock sub. My 96 XLT did not have one.
i thoguht thats where it would be but do u have any idea what that thing is thats back there to do with the radio? i read that some explorers have the "brain" in the back and the radio is just the display for it. but im not sure if thats what it is because i took the radio out from the dash and it seems like its all right there. im thinking maybe a previous owner had that display problem that is common and switched radios?
That "thing" back there is the amplifier
Is there a small plug and a big plug going into the factory amp??
yea there is 2 plugs in the bottom of it, but i dont see any sub
I guess you do not have a factory sub...if you did it would be clearly visible behind the rear passenger panel.
i just dont get why i would have the amp without the sub
if I remember correctly from removing my stock amp and sub combo the amp is actually mounted ON the sub enclosure itself
I have an amp back there for my door speakers...its just an upgraded system...factory speakers sound like crap anyhow
