stock fog lights?? | Ford Explorer Forums
stock fog lights??
jlxplorer
citrus heights, california
1993 eddie bauer limited
anyone know where the stock 93 ford fog light relay is?? lights not working its ither the switch or the relay?? no power to the lights but i have power to the switch...
Bump.
I can't find it either, I want to re-wire it so fog lights come on with parking lights. I've got a 93 limited. It's not in the underhood power dist box and can't seem to find it under the dash. Help!
On the 98 its located just below and next to the air filter box in a 2x6 inch relay box. This relay coil is powered by the low beam lights. Just cut and switch it over
Looked there, nothing like that on the 93. How well could they've hidden the darn thing? If it comes down to it I suppose I could start at the fog light and trace wires back until I run in to it, but I'm hoping someone out there knows where it is.
OK. Found the damn thing! It is underneath the dash on the drivers side. There is a gold colored metal bracket to the left of the module that goes "ding-ding" when the door is open and the lights are on. On this bracket is a brown module and three relays. Naturally the fog light relay is the one highest up. Now that I've found it re-wiring it will be a snap!
I've been wanting to do that too. Could you possibly explain the re-wire process? Only wiring I've ever done is with speakers.
Hey man! Do you still have the Explorer? Wich model is it? It´s a XLT or a Limited? Because for what I researched, there is no stock fog lights on the 93 XLT, just the ones that were installed by Ford dealers. Or stock on Limited model. And Im still looking for a stock switch conector for my 93.
