Stock torsion key lift? | Ford Explorer Forums
Fayetteville Georgia
05 explorer sport trac
I want to lift my 05 sport trac maybe 2-3 inches. Can I do that with the stock torsion keys? Or will it hurt my vehicle by lifting too much?
You can do that, but 3" is the max on a 4x4 without putting the half-shafts in a precarious angle.
It depends on how high the factory or previous owner set it. On my '01 it takes 20 full turns on the adjusters to go from top to bottom, which moves the front up/down about 4 or 4.5"
So... If it was pretty much in the middle to start with, then you can raise or lower it about 2" from stock. In theory. In reality, it takes 6 extra turns on the driver side to get it to level left/rigth, so the "useful" range is just 14 turns.
To get a full 3", you can use aftermarket torsion keys, or modify the stock setup.
Will it hurt anything? If 4wd, then hell yes! 3" will destroy the CV joints. So you'd keep it under 2" - just crank em both full up, then back off the high side to level, and you'd be at the top of the safe range.
If 2wd, then you won't hurt anything, but at 3" you'll be at the top uf your suspension travel, unless you get longer shocks the ride will suck. With longer shocks you'll get more travel, but then you'll have to do some grinding for lower ball joint clearance, plus other issues like uca angle & ball joint bind when yuo lift higher.
Most people with 4x4 stay under 2" so the joints aren't overstressed like ncranchero said above. Couple those with shackles or add a leaf in the crack and you've got about a 2-3" lift
