stock vs. coilovers | Ford Explorer Forums
stock vs. coilovers
chrisw2012
tn
2003 sports trac
so I may have not read right but I read somewhere that coilovers replae the shocks or something like that. what is the reall difference in stock vs. coverting to coilovers. I have s 2wd 2003 sports trazc with 3" pa body lift. hat are the pros and cons of converting to coilovers
Pros - no more torsion bars hanging down; more adjustable; better handling and comfort
Cons - expensive, not an off-the-shelf and bolt-in modification
does it take your torsion bars completely out? whem it gets warm I plan on doing a 2 /2in.tt so can I adjust the coilovers to give me the same lift? would any coilover work or do I have to get certain ones? are they seen wen standing outside the truck? and I seen where theymake a 1" lift or coilovers or is that the same as just adjusting them higher
Yes, you would remove the torsion bars. You would need coilovers specific to your application. I haven't looked into them enough to say what but there are a few good threads about this project on the forum you could search out. This is not as simple as "remove the shock, replace with coilover." If it were, we'd all have coilovers.
They'd be visible outside the truck as much as the shocks you'd replace. Are you asking because you want to do this for visual appeal? If so, imo, you can get more bang for your buck through other modifications.
Just in time, there's a member that just put his complete setup for sell, You won't need the control arms because they are different on the ST but the Coilovers, brackets, etc... are what you'd need. Give this guy a call or pm, he can tell you what you need to know.
http://www.explorerforum.com/forums/showthread.php?t=420929
