Strange electrical "waver" 89 BroncoII | Ford Explorer Forums
ragajungle
Chicago, IL
89 BroncoII & 05 Taurus
In the past couple of days in the morning before sunrise when I go out to start the truck All of the power (Fuel pump, interior lights, parking and head lamps) waver ~~~~~~~~~ It goes away a bit when you rev it, but at idle its enough to give you a seizure.
-New Alt, batt, neg cable, pos cable in July.
Volts outta Alt are good, battery tests okay.......just a strange waver - not a flicker, a consistent up and down about 1 second on 1 second off....
Any thoughts
Any guess would be a guess. But on my 88 BII XL I had some reliability problems. I replaced the pressure fuel pump (under the driver's door frame), the fuel pump relay and fuse. Eventually after many failures on the road, I removed the inertia realy under the dash- right hand side under the heater. I jumper wired it out of the fuel pump circuit and the truck has run without a problem for 2000+ miles since removL.
I would look at this uneeded part and determine if you need it. The only time it is necessary is if you are in an accident with high "G'" forces. I would bet that most of us don't anticipate this. So make your choice.
Bill
Bill,
Thank you for the response.
I have heard that from others with the 2nd pump. Mine; however, doesn't have the 2nd pump... The issue doesn't affect the truck at all other than the lights (dash, head lights, and that I can hear the Fuel Pump being affected) I guess I am just worried that it could develop into a future problem. I have seen this happen to multiple GM vehicles - just the other day there was a (1997?) Bonneville in front of me that was doing it. You could see the headlights and tail lights quickly "waver" at a stop light.
UPDATE--Solved
I think it might be a grounding issue.This morning it was "wavering" and went under the hood and jiggled the neg battery cable to see if it affected the symptom - it was loose. Strange because I just put an entire new ground harness on in July... Turns out the cheap-o harness' terminal end (The part that tightens around battery terminal was cracked) I'll be putting a new BETTER Quality one on this wkend. I am leaning toward the newer OEM style metal band and screw set-up.
Update-Unsolved
The waver is back with a vengeance... Now I can watch as the headlights, dashlights, voltage needle on the dash waver/flicker at a fast rate until the truck is warmed up.
>The neg ground terminal is tright
>The ground and all sub grounds have been replaced and are tight
>Alternator new as of July
>Belts new and spec as of July
Could this just be a crap Alternator? (I am sure that the VR/ voltage regulator is built into the Alt on Post '85 Fords)
Thanks for any input
ragajungle I am tracking down a very similar problem. Up until now I have been documenting my troubleshooting in this thread. In the next few weeks I will have more time to troubleshoot and I intend to fix it. Until then here is a site that I found which contains some useful information.
Post number eight in the thread you found by Reejerey is a good test for parasitic drain even though that is not our problem.
This is interesting to say the least. Keep up the good detective work and please post your findings.
Only thing I can think of is...Have you stopped near a train crossing at night, only to have the truck shaking, all your lights blinking, things flying all over in the cab, X-crossing sign shaking and to have some round saucer shaped thing hovering over you lately?
You mean............I am not the only one? They got you too! [insert 1960's sifi music here]
On a serious note I am going to try to pull and swap the Fuel Pump Relay...Reason being is that even with the lights off in the morning the gauge dashes and dances a bit and the only thing pulling and draw is the Fuel Pump. So it reasons that somewhere in there something is not making good contact or creating too much of a draw... Looks like I may recheck all my FP wiring too...
this is what the space capsule looks like everytime the strange loss of power occurs:
It is some sort of hideous terrestrial transport pod
