Mikey*TX
- February 3, 2020
- Skunk Hollow, TX
- 2021 ST Star White
Feed the mice ........ Jus say'n
I was driving my XLT today and noticed a strange sound coming from the dash area or engine bay. At around 45 MPH you can start to notice something sounding like paper being crumpled. As I got faster the noise gets louder and more frequent. Its obvious that the wind is playing a factor in this sound. Any thoughts?
Welcome to the Forum.
It sounds like your noise is 'speed' dependent. Have you checked to see if the cowl is loose? Noises can be difficult to track down and it could be coming from outside, especially if only occurs between 40-70 MPH.
strange
I have a similar problem as well. Purchased on Saturday and noticed it driving home. For mine I have to be going 70 to hear it but it gets louder the faster I go. Obviously I'm very disappointed at the moment. Will be taking it in this week. Really sounds like it's in the steering column to me.I have the same problem with my 2020 XLT. Sounds like it's coming from inside the dash below the instrument cluster.
As others have described, relays chattering, HVAC actuator searching sounds that you would expect from a worn out vehicle, paper crumpling, sparking?, and it occurs intermittently at highway speeds (at least) between 40 and 70 MPH. Does not inspire confidence at all. Eventually, someone will figure it out and we get if fixed.
Welcome to the Forum Jason.
I was not able to hear the sound above the driving noise. If it seems to be 'speed depended' it could be the cowl. Have you checked to it to see if it is loose at all? The cowl was an issue on some of the 5th gen Explorers.
The cowl is that piece that runs along the outside bottom of the windshield. Between the hood and the windshield.thanks I can look into that. Though I’m not sure what a cowl is. Ha.... also it’s weird the noise isn’t noticeable on that Youtube clip but the same video on my phone it’s very noticeable. Anyway thanks
Yeah thanks I looked it up. It’s definitely different than that. It’s almost like a clicking noise. I’m annoyed it didn’t show up in the video! Appreciate your help regardless!The cowl is that piece that runs along the outside bottom of the windshield. Between the hood and the windshield.
I am taking mine in tomorrow morning. I will update tomorrow what they say. Hoping for an easy fix!I have the same rattle. Sounds like paper or plastic flicking against something. Could also be a fluttering relay. Either way it’s annoying me immensely. Need to get it in and looked at.
Not much of an update. They confirmed the noise but couldn’t find the source. We’re bringing it back when they can keep it for the whole day. UghI am taking mine in tomorrow morning. I will update tomorrow what they say. Hoping for an easy fix!
Took the Explorer on the interstate today. The noise was still there but definitely a lot less noticeable. I’m at 800 miles today. We take it back to Ford tomorrow, but now I’m wondering if it’ll continue to resolve itself....The next time it happens for me, I'm going to turn the temperature control panel off to see if that does anything. This thread gave me the idea,
ST HVAC (cold/hot air) System Noises/Problems
Is anybody else experiencing “popping/cracking” noises coming from the system. Generally during initial start up if the vehicle has been sitting, is when I hear it the most. For the first 10-15 minutes my system makes a lot of noise. I took it to the service center and the tech said “unable to...www.explorerforum.com
I checked the bolts under the drivers side undercarriage that holds the felt panel on and found one toward the front that was loose. Just by tapping the panel I was able to make it vibrate. Tightened it up and the noise is now gone.Not much of an update. They confirmed the noise but couldn’t find the source. We’re bringing it back when they can keep it for the whole day. Ugh
Nice I’ll check that too. Service advisor called me and said the battery connector was looseI checked the bolts under the drivers side undercarriage that holds the felt panel on and found one toward the front that was loose. Just by tapping the panel I was able to make it vibrate. Tightened it up and the noise is now gone.
It doesn't seem like the location of what you found would coincide with where the noise was coming from (near/behind instrument cluster) could you post a picture of where and what you did and clarify location better? Thanks.I checked the bolts under the drivers side undercarriage that holds the felt panel on and found one toward the front that was loose. Just by tapping the panel I was able to make it vibrate. Tightened it up and the noise is now gone.
