Mic_
- December 16, 2004
- SE MI
- '94 XLT
I’ve search for a few things to check, but need HELP!!
Situation: I have a stumbling idle.
First vacuum leak I found was on the fuel regulator.
Snapped that back on.
Still have a stumbling idle to almost to a die, but not quite.
Cruises fine.
I’ve cleaned the MAF and cleaned the IAT; and examined the IAC (looked ok).
Disconnected the battery for a while.
I’ve checked for other vacuum leaks and found none.
Please help
Prior to any work had these:
KOEO:54 35 43
CM: 32 75 43
After disconnecting the battery the CM’s went away but the
KOEO remain: 54 35 43
And KOER: 44 35 43
Cruises fine.
Please help
KOEO:54 35 43
CM: 32 75 43
And KOER: 44 35 43
