imnotted
- July 9, 2004
- the Albuquerque.
- 98 V8 XLT
I recently purchased a 98 XLT with the mach audio system in it. IMHO, the subwoofer was way too weak. QLogic wants ~$200 for their 10" box, and I'm cheap. Thus, I have undertaken a box building project. I've spent the past month designing it on paper, and now I've begun fabrication.
As you can see with the pic below, it's pretty close to the factory box but has a volume of .57ft^3 and can support a 10" sub, 5.375" depth. It's also made of 5/8" particle board (1" thick on the face). It's not perfect, but with the plans tweaked a little and some glue/sawdust mix and silicone, it should prove to be a worthy replacement. If anybody wants the plans to this, I can scan them and merge them into PDF format once I'm done and I've tested it in the explorer. I'll update in a week when I should be done with fabrication and testing.
