Sudden Engine Stop Problem | Ford Explorer Forums
shogun2006
Lima
'00 XLT EDDIE BAUER
Hi Friends, I Have A Problem With My '00 Ltx Eddie Bauer. While Driving And Reaching 2,800 Meters( 8,500 Feet) The Engine Suddenly Stops. I Have To Wait 5-10 Minutes,then It Runs Again For A While And Again The Same Problem. At Sea Level And At Lower Altitudes Than 8,000 Feet There Is No Problem.
This Problem Appeared When Reach The 50,000 Km (31,000 Miles), Before That Mileage I Have Travel At Higher Altitudes With No Problem.
I Have Change The Fuel Pump,but The Problem Remains.have Scanned The Sensors At Sea Level,and Everything Seems To Be Ok.
I´ll Appreciate Any Help To Find And Solve This Problem. Thanks.
When it won't start, you need to determine if it's fuel or spark related. If you turn the key to the ON position, do you hear the fuel pump run for a second or 2? If not, then it's probably fuel delivery related. If you do hear it, then check for spark.
