jmden
- November 4, 2013
- Washington State
- 1997 Explorer
Any help would be appreciated. I have had no trouble with this tranny til now. 181K miles on a 97 V6 4.0. Just tonight coming home from Thanksgiving dinner at mostly freeway speeds it would 'slip' (best I can describe) and there would be this sound like gears hitting each other at hi-speed.
The first time it happened we were going down a grade and I went to put it in D2 for a little compression rather than braking and it 'popped out'. I immediately put it in neutral and when we coasted to the stoplight at the bottom of the hill, I put it back in drive and we went on our way. But, then several more times when going downhill or braking while at freeway speeds, it would 'slip-out' of gear again. Each time this happened I would put in neutral quickly and the gears would stop spinning. However, each time this occurred and the rig was put in neutral, it seemed like the gears were spinning for a longer time before slowing down. We would pull to the side of the road, wait a couple of minutes, put it in drive and would be fine for a few miles of freeway travel.
I checked the tranny fluid, of course, and the level, color, etc. seemed fine. In the dark with a flashlight, I did notice a little fluid on the bottom back end of the tranny, which I have not seen before and I was under this rig with a couple of techs 2 weeks ago while it was on a lift and no one saw anything wrong.
Not an Elite member, whatever that means, and can't post in the 911 sub-forum.
