rgiles
- October 27, 2002
- San Jose
- '91 XLT, '02 Limited V6
I want to add an inline Magnefine filter and switch to Synth ATF on an '02 explorer. Since it is under warantee, I want to do it by the book so that there isn't any way that claims of voided warantee can hold up.
Can an OBDII scanner retrieve Transmission Fluid temperatures on an '02 Explorer? Is there any way to get the temp with the Message center that is standard equipment? I want to measure the temperature for changing the fluid (it needs to be between 80-120 degrees F) in order to get the correct level. Not looking for the most expensive approach, but if an OBDII scanner can do it, then I would consider getting one as it would be nice to have anyway.
In the Ford Service manual it says to use a Worldwide Diagnostic System (WDS) New Generation Star (NGS) tester to measure the temperatures. This sounds like an expensive piece of equipment to me.
Also, any opinions on additives that convert Mercon or Dextron Fluid to Mercon V? Is this a safe approach to go? Mobile 1 and Royal Purple don't support Mercon V, but with an additive I suppose it could.
Any Ideas?
Any Ideas?
