sunroof in a 99 XLS 4 door | Ford Explorer Forums
duketter
ND
'99 XLS Sold
Ok, looking to put in a sunroof in my 4 door xls 99 explorer. Only one place in my town does this, i trust them and they also give a lifetime warranty but here is my question.....
Anybody have any manual sunroofs in their X, like I got? They say they have to take out the dome light(ok, reasonable), but can't they move it elsewhere. I actually use that thing sometimes! Also, what size sunroof did you have put in your X?
Thanks!
WELL, THER ARE A COUPLE OF OPTIONS YOU GOT...
1. YOU CAN GET AN OVERHEAD CONSOLE, (WHICH HAS LAMPS) (WHICH I DID) YOU CAN GET THEM CHEAP OFF OF EBAY OR JUNKYARD BETWEEN $20- $60. (YOU WILL NEED THE
1. THE CONSOLE, 2. THE WIRE HARNESS- A MUST..JUST A LITTLE SO YOU CAN SPLICE INTO IT AND RUN YOUR OWN WIRES AND IF YOU WISH TO KNOW THE OUTSIDE TEMP. 3. THE SENSOR- LOCATED IN THE ENGINE COMPARTMENT DRIVERS SIDE BY THE RADIATOR...OR PAY THE BIG BUCKS AND GET IT FROM FORD FOR OVER $500. YOU CAN INSTALL THEM YOURSELF, IT IS EASY...THERES A TREAD UNDER TIPS TO HELP YOU THRU IT...I USED IT, AND IT ONLY TOOK ME UNDER 2 HOURS...
2. RELOCATE YOUR MAP LIGHTS RIGHT ABOVE THE REAR SEATS HEAD REST...THERE S H O U L D BE ALREADY MOUNTING HOLES THERE....(THATS WHERE MAP LIGHTS ARE WITH EXPLORERS WITH SUNROOFS)
IF YOU DONT WANT A MANUAL SUNROOF....GO TO A JUNKYARD AND FIND AN X WITH A SUNROOF, AND REMOVE TAKE THE OVERHEAD CONSOLE AND BRACKET AND UNDER IT IS THE SUNROOF MOTOR, G R A B IT...AND THERE YOU GO! A MOTOR, A CONSOLE WITH THE SUNROOF BUTTON AND A MOON ROOF!!!!!!!
HOPES THIS INFO HELPS YOU IN QUEST...
Stop yelling.
seriously Big Country, dont type in caps.....you could be banned from the site if you do it too much:(
oh, sorry....just a habit...its easier for me to read
