94Eddie
- September 18, 2003
- 2010 Mountaineer Premier
The first thing I took out was the T5 manual transmission. I was doing a low RPM pull in third dear and POW, the transmission was toast. Installed a T56 six speed. Then the Ford upgraded clutch went out and was replaced with a SPEC Stage 3 part. Then the stock differential got the clutch packs fried. I ended up keeping it and rebuilding it with an extra clutch plate on each side. This held but if I ran slicks and launched hard it might not have. While it probably would not have failed, I installed a beefy aluminum drive shaft. I also preemptively moved to 31 spline five lug axles because this was a known weakness for high low end torque builds. I think the last thing was beefier motor mounts. Some of these are preemptive but I think all but the drive shaft would have failed eventually. I was making 462 ft-lbs of torque at 2,100 RPM at the wheels and over 400 ft-lbs to redline. That little 302 pulled like a diesel in the lower RPM range. Also, I was running 16 psi with water injection and a J&S Safeguard to control detonation. The J&S Safeguard is an amazing piece of electronics.Ok what did you break?
was it on this drive train?
Your getting me worried now
The hardest pulls will be the data logging and tuning
I was more joking with my comment. Since you are working with a 4.0L and less boost you probably won't have any issues. That said, I also don't know the strengths and weaknesses of your particular drive train. The big item is to control detonation which you are addressing with water injection and a tune. I know many 4.0L engines in Mustangs have been supercharged but the ones I know about have all used centrifugal blowers which don't deliver much of a power increase under 4k RPM. I think you will be fine if the tune and water injection is dialed in. Also, 4X4 components are beefier, in general, for off road use which is working in your favor.
