superlift part numbers | Ford Explorer Forums - Serious Explorations
blueka
Elite Pickler
Location
Liverpool
UK
97 UK XLT, 99 Sport V8,
Hi guys, having trouble finding the info on this site and superlift site...
I'm looking into getting the K494 4" lift kit for the 99 Sport...
http://www.superlift.com/Catalog.asp?P=k494#nogo
I'm guessing I don't need the 9637 part as it seems to be for the Sport Trac... would I be correct in my assumption?
Si
From what i have learned about the superlift all you would need is part packages #9633 for the front and both #1147 and #01-194 (leaf springs).
I would say you are right with your assumption though.
Last time i had talked with them the front kit for the sport trac was due to the bigger brakes. but the kit i bought from a friend was a new updated kitthat had multiple mounting holes for the caliper brackets. so wen I called they told me they kept the site like that so no one got confused for you id just get the complete kit K494. if it helps i will take pics tomorrow at work.
sure, if that's no problem for you...
I just didn't wanna order too many parts and pay more on shipping and be left over with a pile of crap that I don't need... trying to do this on less than no budget...
Si
I couldn't get a picture of mine covered in mud and all but here's what I'm talking about all the kits made from 07 and up I was told are like this.
If you're ordering one right now, you should probably be prepared to wait. Unless you manage to find a distributor that has one in stock, the kit has to be made. I ordered mine on December 15th from 4WheelParts.com and called last week to find out the status. Superlift had to make it, and they said four to six weeks. I would hope they did an actual run with a few kits, but they may have made just the one, I dunno.
So for those that plan to SOA the rear is all you need part #9633?
I think that kit is actually only shocks and related hardware. I don't believe you get the knuckles.
So which part number is needed just for the front (non-Sport Trac, no shocks)?
Ok i just read the site it looks like if you want just the front you need both the #9633 and the #9637
#9633 front box kit come with everything but knuckles
Part # Description
01-85156 Shock Cylinder-Bulk 29.82/17.45, Bp8/Es34
01-85330 Shock Cylinder, Bulk 15.25"/22.0' Bp7/S1 Hardware Bag Not Includ.
55-04-9630 Brkt, Pa & Dr Ft. Diff. Drop, 1998 Ranger
55-05-9630 Brkt, Crossmember Drop
55-06-9630 Tube, Front Crossmember
55-07-9630 Tube, Rear Crossmember
55-08-9630 Brkt, Diff. Lateral Supp 1998 Ranger
55-09-9630 Brkt, Pa Compression Stp 1998 Ranger 3 1/2" Tall - zc
55-10-9630 Brkt, Dr Compression Stp 1998 Ranger 3 1/4" Tall - zc
55-16-9630 Brkt, Frt Brake Hose 1998 Ranger
55-21-9630 Brkt, Diff. Drop Driver Side Rear-Pc
55-24-9630 Brkt,Pa. Torsion Bar -Pc Drop
55-25-9630 Brkt,Dr. Torsion Bar -Pc Drop
55-30-9630 Sway Bar Drop Link,Pc 98-02 Ranger/01-02 Sport Trac - ZC
77-87015 Hdwe Bag For Shocks 9638 & 9633
77-9633 Hardware Bag For 9633
KB2015 Used W/55-37-3280, 55-26-9630,55-08-4640
then you'd need #9637 Front Kit Box, 4" Lift 2001-Up Ford Explorer Sport-Trac
it contains
Part # Description
66-01-9636 Knuckle, DR (RED NO ABS TUBE)
66-02-9636 Knuckle, PA (YELLOW, NO ABS TUBE)
77-9630 Hardware Bag - 9630 Kit
If you want to get technical you could look at the downloadable installation sheets and look at the parts list and match the part numbers with what i just posted.
nice one... the place we contacted said they had one in stock... but that was at the beginning of December
Si
Summit doesn't even show em in stock anymore they're about a month out before shipping straight from source.
